Use this procedure to configure subnet routers (default gateways) to advertise to clients within a DHCP Server subnet.
  1. In the navigation pane, expand Configuration > IP.
  2. Select DHCP Server.
  3. Select the Subnet Routers tab.
  4. Select Insert.
  5. In Subnet IP, type the subnet network address.
  6. In Subnet Mask, type the subnet mask.
  7. In IP, type the router IPv4 address.
  8. Select Insert.
Subnet Routers Field Descriptions
Use the data in the following table to use the Subnet Routers tab.
Name Description
Subnet IP
Specifies the network address of the DHCP subnet.
Subnet Mask
Specifies the subnet mask for the DHCP subnet.
IP
Specifies the IPv4 address for the subnet router (default gateway). You can assign up to eight router addresses.
